Bolt displacement not matching expected result
I'm getting a weird result when I run a Normal Modes analysis on my part.
I have a number of sheet metal pieces with separation surface contacts that are bolted together using bolt connectors. When I try to run a linear static simulation I can't get convergence on contact, so I was going to try a normal modes simulation to try to see what might be happening.
When I run it, I get four bolts (which are supposed to be clamping 3 pieces of sheet metal together) that are showing impossibly large displacements (460 mm).
I do not know what's going on, or how to fix it.
I suspect it has something to do with a warning I received (R4030: Unable to maintain minimum preload in one or more elements), but I can't figure out why that would happen or how to fix it.
Any help would be appreciated.
John_Holtz
Autodesk Support
Autodesk Support
Hi @Anonymous
My guess is that the material properties for the bolts are wrong, and therefore the "spokes" that connect the bolt shank to the model are allowing the bolt to vibrate axially. (The "spokes" are not shown in the results.) In particular, make sure the modulus of elasticity is a real value and the shear modulus is blank.
The other possibility is a problem with the contact between the pieces that are bolted together. A modal analysis would not be able calculate separation contact. I do not remember if In-CAD automatically converts separation (and other types of) contact to bonded contact or not. Could you try the modal analysis with the contact types set to bonded (or offset bonded if there are gaps between the parts).
John Holtz, P.E.
Global Product Support
Autodesk, Inc.
If not provided already, be sure to indicate the version of Inventor Nastran you are using!
"The knowledge you seek is at knowledge.autodesk.com" - Confucius 😉
I think the issue was due to contact. There seemed to be some contacts that weren't detected when I ran the auto-contact and I hadn't noticed when I went through them. Adding the contacts seems to have resolved the issue.
Type a product name
______
icon-svg-close-thick
Cookie preferences
THIRD PARTY SERVICES
icon-svg-hide-thick
icon-svg-show-thick
Qualtrics
Akamai mPulse
Digital River
Dynatrace
Khoros
Launch Darkly
New Relic
Salesforce Live Agent
Wistia
Tealium
Upsellit
CJ Affiliates
Commission Factory
Typepad Stats
Geo Targetly
SpeedCurve
Qualified
icon-svg-hide-thick
icon-svg-show-thick
Google Optimize
ClickTale
OneSignal
Optimizely
Amplitude
Snowplow
UserVoice
Clearbit
YouTube
icon-svg-hide-thick
icon-svg-show-thick
Adobe Analytics
AdWords
Marketo
Doubleclick
HubSpot
Twitter
Facebook
LinkedIn
Yahoo! Japan
Naver
Quantcast
Call Tracking
Wunderkind
ADC Media
AgrantSEM
Bidtellect
Bing
G2Crowd
NMPI Display
VK
Adobe Target
Trendkite
Hotjar
6 Sense
Terminus
StackAdapt
The Trade Desk
RollWorks
Your experience. Your choice.
