Announcements
Starting in December, we will archive content from the community that is 10 years and older. This FAQ provides more information.
Inventor Nastran Forum
Welcome to Autodesk’sInventor Nastran Forums. Share your knowledge, ask questions, and explore popular Inventor Nastran topics.
Primary membrane stresses(Pm), Bending stresses(Pb), Local membrane stress(Pl)
7 REPLIES 7
Message 1 of 8
1538 Views, 7 Replies
Is it possible  for nastran to calculate the primary and local membrane stresses and the bending stress?
In the stress linerization tool, i can get the Pm and Pb, but i really need to get the local membrane stress too.
It is on a rectangular plate.
Best regards.
7 REPLIES 7
Message 2 of 8
sohan.kumar.thiruvakkadu
Hi @Anonymous
Can I know what do you exactly mean by Local membrane stress and why do you need it?
Do you have any reference image, sketch or calculation which can clarify on local membrane stress.
Sohan Kumar
Global Product Support
Message 3 of 8
I need to calculate the stresses in a heat exchanger due to a “Danish standard, EN13445 Annex C”. Thise stresses had to be evaluated due to get the heat exchanger on the market and acceptable by a second Company.
Message 4 of 8
dreierWTK29
You can use Pm from the stresslinearisation tool. You have to check areas in which the stress is higher because of gross structural discontinuity such as nozzles or flanges. See the definition in table C  - 3 of EN 13445.
Message 5 of 8
in reply to: dreierWTK29
But i have to use Pm and Pl Also. NOT only pm from the stress tool
Message 6 of 8
John_Holtz
Hi @Anonymous
Perhaps because I am not familiar with the Danish specification, it is not clear to me what is meant by the "local membrane stress". That is why Sohan was asking for some information (an image, sketch, something to explain what it is, how it is calculated, and so on).
Unless the "local membrane stress" is just the "X-Normal", "Y-Normal", or "Z-Normal" stress in Nastran,  Nastran will not provide the answer that you want. Hopefully the specification will explain how you can calculate it. (The "X-Normal", "Y-Normal", and "Z-Normal" are the stress (tension or compression) at the nodes in the local directions.)
John Holtz, P.E.
Autodesk, Inc.
If not provided already, be sure to indicate the version of Inventor Nastran you are using!
"The knowledge you seek is at knowledge.autodesk.com" - Confucius 😉
Message 7 of 8
dreierWTK29
in reply to: John_Holtz
My understanding of the definition is shown in the following picture. I hope this helps.
Message 8 of 8
That helped a lot. Thank you very much!
