Pin Constrain Vs Real Pin behavior
CCarreiras
CCarreiras
Hi!
When we apply the pin constrain in this shaft we get this result:
This deformation behavior doesnt represent correctelly the real conditions.
I Saw this result (image below), but i cant  get the same result.
I create a Rigid body in the external faces, and a fix constrain in the center point (already in the model), but i cant get the kind of deformation as the image below. Any help?
CCarreiras
John_Holtz
Autodesk Support
Autodesk Support
Hi Carlos,
Some day I will write a book. Chapter 1 will be "Rotations do not exist in life or FEA" Smiley Happy
Your first example with the constraints on the face is not in the model, but from the image it looks like you have TxTyTz constraints on the face of the shaft. The problem is this prevents the nodes from moving in the manner that is required for "rotation". So those constraints are not correct. This figure tries to explain the concept.rotations do not exist.png
Figure 1:
1. If this face is constrained in TxTyTz ...
2. ... how can the nodes move to this location? (That is the motion that would be required in order to simulation rotation.)
You were close to the correct solution with the rigid connectors. The problem is the constraints you applied are fully fixed which prevents the connectors from rotating about the Y axis. You need to free the Ry in the constraints. (The connectors can only transmit forces to the nodes on the shaft; a solid element cannot accept a moment load. So technically the connectors only need to have Tx Ty Tz checked.)
John Holtz, P.E.
Global Product Support
Autodesk, Inc.
If not provided already, be sure to indicate the version of Inventor Nastran you are using!
"The knowledge you seek is at knowledge.autodesk.com" - Confucius 😉
CCarreiras
I was close... Releasing Ry did the trick, and worked well, Thank you!!
CCarreiras
Type a product name
______
icon-svg-close-thick
Cookie preferences
THIRD PARTY SERVICES
icon-svg-hide-thick
icon-svg-show-thick
Qualtrics
Akamai mPulse
Digital River
Dynatrace
Khoros
Launch Darkly
New Relic
Salesforce Live Agent
Wistia
Tealium
Upsellit
CJ Affiliates
Commission Factory
Typepad Stats
Geo Targetly
SpeedCurve
Qualified
icon-svg-hide-thick
icon-svg-show-thick
Google Optimize
ClickTale
OneSignal
Optimizely
Amplitude
Snowplow
UserVoice
Clearbit
YouTube
icon-svg-hide-thick
icon-svg-show-thick
Adobe Analytics
AdWords
Marketo
Doubleclick
HubSpot
Twitter
Facebook
LinkedIn
Yahoo! Japan
Naver
Quantcast
Call Tracking
Wunderkind
ADC Media
AgrantSEM
Bidtellect
Bing
G2Crowd
NMPI Display
VK
Adobe Target
Trendkite
Hotjar
6 Sense
Terminus
StackAdapt
The Trade Desk
RollWorks
Your experience. Your choice.
