Good Morning,
I have been trying to get a part i have conceptualised to mesh within my vibration test assembly. I was attempting to setup up a Normal modes test case for 140Hz to 2000Hz at 60g.
I have followed all the work flows that i could find on the forum for work arounds see following:
1. Make sure the part has a Idealization.
2. Make sure the part thats not meshing CON-EXP-15438 has no geometry error CTRL+F7
3. Make sure the Assembly that contains CON-EXP-15438 has no geometry error CTRL+F7
(To big to screen shot but no bad parts or features).
4. CON-EXP-15438 meshes on its own in the part simulation environment.
5. Interogated part feature tree to remove unused sketches and geometry.
6. Exported to stp file and imported as single body (CON-EXP-15439) and it meshed once and never worked again within the assembly.
7. Tried varying mesh sizes no effect.
Can anyone help any further work arounds or investigations i can perform? Parts described attached.
@John _ Holtz
