We use FEMAP (with Siemen's Simcenter Nastran), and our client uses Autodesk Nastran.
We'd like to supply results to them, which they can view in Nastran Editor.
The .dat file opens with no problem. And then in theory all they need to be able to do is open the results file which is normally a .OP2.
I see that Nastran Editor opens results in FEMAP neutral file format. We have tried exporting a FEMAP neutral file from FEMAP with the results, but they don't seem to load in the Nastran Editor.
Is there any trick to getting FEMAP to export the results in a file which Nastran Editor to open ?
Is there any way to get Nastran Editor to import results directly from a Nastran OP2 file ?
Thank you for your help.
Fergus
