Nonlinear buckling vs LBA
autodesk428JLG
Message 1 of 8
autodesk428JLG
Hi!
I did two analyses in buckling, linear and non linear and got 1500 load multiplier in LBA and 7000 in nonlinear which to me , after what i read about LBA is weird. Usually the LBA is overestimated right?
Is there certain things i need to click in the advance settings for the nonlinear settings? I realized i forgot to click the arc length option and running my analyse with that clicked as im writing this to see if thats the issues. Can someoe elaborate on the arc length option please?
Best regards, Daniel
Replies (7)
Message 2 of 8
Roelof.Feijen
Hi Daniel,
So you got an eigenvalue of 7000? If the eigenvalue is far above 1, then the applied load is below the buckling load. If the eigenvalue is not close to a value of 1, consider adjusting the applied loads by the calculated eigenvalue and re-running the analysis. Repeat the process until the buckling load multiplier is approximately 1.
As for the arc-length method, this will allow the solver to reach convergence with a lower applied load and find the equilibrium. The highest reachable Load Scale Factor can be used to calculate the buckling load. You can also use this to see the post-buckling response.
I would like to suggest that you do not use the arc-length option for now, but adjust the applied load first to a reasonable value.
Roelof Feijen
If my post answers your question, please click the "Accept Solution" button. This helps everyone find answers more quickly!
Message 3 of 8
autodesk428JLG
Well, i got a higher eigenvalue for the nonlinear analysis, 7 times higher, after what i read the linear analyses often over predicts the buckling loads(?). However, i can see that i get two different buckling scenarios where the LBA mode kind of looks like i would excpect, but the nonlinear show a more twisting thing, see below:
Message 4 of 8
autodesk428JLG
So,
LBA, Mode 1, 100 in eigenvalue and nonlinear, mode 1, 700 in eigenvalue
Message 5 of 8
John_Holtz
Autodesk Support
Autodesk Support
Hi @autodesk428JLG
The two buckling shapes look completely different, so they are finding different frequencies. The linear result looks like buckling in compression, and the nonlinear result looks like the beam is twisting. You should look at the stress result in the nonlinear analysis (probably identified as "subcase 3") to make sure the load is not causing the model to twist.
John
John Holtz, P.E.
Global Product Support
Autodesk, Inc.
If not provided, indicate the version of Inventor Nastran you are using.
If the issue is related to a model, attach the model! See What files to provide when the model is needed.
Message 6 of 8
autodesk428JLG
Good morning!
So, i have contacts as below for my special beam: Offset bonded(Weld) and seperation.
So, you are saying that axial loads in my model, due to the setup of my welded beam, will make it twist before it buckle? I cant see from the result that those are super high:
Message 7 of 8
Roelof.Feijen
Your non-linear buckling analysis contains a Beam idealization, which is not present in the linear buckling analysis.
What is the purpose of this Beam idealization?
Roelof Feijen
Message 8 of 8
autodesk428JLG
Its just my wire that isnt constrained or anything so its just there from the static analysis i did 😃 I think however i got the twisting buckling thing due to the fact that i forgot the friction coefficient.
