Dear Nastran In-CAD users,
I am looking to perform a simulation of non-linear contact between a ring and a cone.
Below is a diagram of the initial position as well as the final position.
I have tested many solutions but I can't find a setting that allows me to get a correct contact between these two parts. The ring is made of ABS and the cone is made of aluminum.
I’m using the last version of Nastran In-CAD as well as the last version of Inventor.
My settings are the following:
Slave Entities:
Master entities:
Questions:
The assembly file is available in appendix
Thank you in advance for your help,
Best regards,
Serge Gugelmann - Technik
s.gugelmann@ricone.de
RICONE GmbH
Trausnitzstraße 8
D-81671 München
Slave Entities:
Master entities:
Questions:
Best regards,
RICONE GmbH
Trausnitzstraße 8
D-81671 München
Solved by Roelof.Feijen. Go to Solution.
Hi @Anonymous
Could you also add the two IPT files?
Assembly only is not enough.
I have my doubts about the Constraint in Red (Face 12).
This simulation is definitely possible in Nastran in-CAD.
Hi @Anonymous
hi @Roelof.Feijen,
You right, sorry I forgot the .ipt files. I added them to this message.
Regarding the constraint in red (Face 12), I put this constraint after reading this article:
Maybe I misunderstood the solution.
I thank you in advance for trying to help me, I appreciate it!
RICONE GmbH
Trausnitzstraße 8
D-81671 München
hi @Roelof.Feijen,
RICONE GmbH
Trausnitzstraße 8
D-81671 München
Thank you for the other IPT's. I will take a look at it now.
You're welcome, that's very kind of you @Roelof.Feijen 🙂
I hope you can help me move forward a little bit with this simulation
RICONE GmbH
Trausnitzstraße 8
D-81671 München
RICONE GmbH
Trausnitzstraße 8
D-81671 München
Hello @s.gugelmann,
I have been struggling with your model for some time, although this should not be too difficult to solve.
There is a problem with Cone_Halb.ipt. First, I thought it had something to do with the derived part missing. However, it is not. I save the file as a Step and imported it again (I saved it as Ring_Halb2.ipt by mistake). Placed everything in a new assembly and recreated the analysis.
Note the changes that I made in relation to your analysis:
1. I used a quarter of the model instead of a half. This makes it easier to constrain / stabilize the model. It will also reduce the number of contact elements and nodes.
2. Contacts
Penetration type = Symmetric contact
Stiffness factor = 0.01 (because of the difference in stiffness between the ABS and Steel. With Steel – Steel I would use a Stiffness factor of 1, but not in this case.)
Master face should be the outer face, slave should be the inner face.
I selected less contact faces, which creates less contact elements.
Added a maximum activation distance of 10 mm. Again to create less contact elements.
3. Nonlinear setup > Advanced Settings
Stiffness Update Method = AUTO
Convergence on only Displacement and Work.
4. Mesh use linear instead of parabolic. I preferred linear in these kind of analyses.
The files without results are attached.
If you want to have the files with results, you can download them here https://we.tl/t-LdUAsyZTIP
(Note: Link is available for 7 days).
Hello @s.gugelmann,
2. Contacts
Hi @Anonymous,
Note that I made some changed to the default Nastran settings / parameters.
Not sure what will happen if you the analysis that I created.
Otherwise Reset the parameters to default.
Hi @Anonymous,
Hi @Roelof.Feijen,
That's fantastic! Thank you so much for the time you took to explain and solve my problem!
I'm going to need a little time to analyze your simulation and understand my mistakes. But I have everything I need!
I also download the complete file, it also works for me! Great. Thank you also for the detailed explanations of the contact settings, it helps me a lot.
As you may have noticed, I am not yet a Nastran In-CAD specialist, but I am very good with Autodesk Moldflow. So if you have any problem with Moldflow, let me know!
Best regards,
Serge
RICONE GmbH
Trausnitzstraße 8
D-81671 München
Hi @Roelof.Feijen,
Best regards,
Serge
RICONE GmbH
Trausnitzstraße 8
D-81671 München
