Hi @neil.harrisCVPSJ
I should have clarified this in regards to your original post. When you received the buckling multiplier of -2.2, that is only the lowest buckling shape. If you had requested more than 1, then the first positive multiplier would have been what you wanted. You are accomplishing the same thing by limiting the output to positive values only. (In other words, it is still calculating the result of -2.2 but it does not output that result.)
For a linear buckling analysis, I agree that a positive load that gives multipliers of -A < +B < +C and so on, would give multipliers of -C < -B < +A and so on for a negative load. (It may be hard to get Nastran to output all those values because I think the tendency is to ignore the negative values. Whether the search algorithm is successful at rejecting the negative values is a different question.) However, you are performing a nonlinear analysis, so the displacement results due to the positive load do not need to equal the same displacement results (but in opposite direction) for a negative load. That's the definition of nonlinear: multiplying the load by X does not cause the displacements to be X times larger.
The next question is can the load be reversed in your situation? For example, if it were a snow load, snow can only push in one direction. There is no reason to worry about changing the direction of the load and calculate "matching" load multipliers. If your load can only act in one direction, you should try to set the Options as follows:
- Number of modes: calculate N modes so that you can see what happens from one buckling shape to another.
- Lowest value: 0.01
- Highest value: blank.
This will tell the analysis to calculate the first N values that are larger than 0.01. There is no reason to calculate all values between the lowest and highest; that is what happens when you enter both the lower and upper limit.
Another example is wind. Wind only pushes in one direction, but the direction of the wind can be from any orientation. On a rectangular building, a positive load blowing north and a positive load blowing south should produce produce similar results, equal and opposite. Likewise, a positive load blowing north and negative load blowing north should create the same result. (I am assuming that most buildings experience small displacements so a linear analysis would create "equal and opposite" results for + and - loads blowing north or south. Of course, I am ignoring local effects that occur on the windward side such as windows breaking!)
Hope I have not made things more confusing. (If so, just ask for clarification.)
John
John Holtz, P.E. Global Product Support
Autodesk, Inc. If not provided, indicate the version of Inventor Nastran you are using.If the issue is related to a model, attach the model! See What files to provide when the model is needed.
