Modeling of springs as a boundary condition
Hello everyone,
I am currently trying to perform a calculation with Inventor Nastran 2020.
I have a solid model that is supported on six springs in reality. The springs each have a stiffness of 200 N/mm.
The springs sit in a holder (see picture). To model the springs, I connected the bottom surface of the holder to the center of the surface using a rigid body connector. I place the respective springs at this point.
I entered a value of 200 N/mm for the stiffness of the springs in the longitudinal direction. I have defined the remaining stiffnesses as 0.1 N/mm, as I only want to look at the stroke oscillation of the system initially.
The first simulation I want to run is a modal analysis to determine the natural frequencies of the system.
This is where I noticed the first inconsistency in my simulation. When calculating the first five natural frequencies and associated modes, the system's stroke oscillation along the local Y-axis is missing. I calculated this natural frequency by hand. Since the stiffness of a spring is 200 N/mm, the total stiffness is 1200 N/mm in the Y direction. The mass of the solid is 790 kg. According to my manual calculation, this results in a natural frequency of ~ 6.2 Hz (in the Y direction).
I have also attached the results. This shows that the calculated frequency is not the result of the
simulation is available. Furthermore, the calculated natural frequencies of the simulation do not include a pure stroke oscillation in the Y direction.
In my opinion, the first three frequencies with ~ 0 Hz are due to the low transverse stiffnesses, as there is hardly any resistance to movement in the X and Z directions.
Now my specific question would be whether I have modeled the springs correctly as a boundary condition?
And why the natural frequency I calculated does not appear in the Inventor Nastran solution?
Even when refining the mesh, the solution values do not converge towards the natural frequency of 6.2 Hz.
@John_Holtz can you help me with this problem?
Thank you for your answers.
Best regards
Luca
