Hi @autodesk428JLG
I am not sure in which direction you are hoping for a "finer mesh size". In the plane of the contact? Perpendicular to the contact?
I think it is not correct to say that the contact creates "surface elements". Contact connects a node on the secondary face to the entire element face on the matching primary face and transmits a force. If the gap between the two contact faces is 0, the force transmitted is the same as when where is a gap of 10 meters. (Ok, 10 m gap is an exaggeration.) There is no element size of any consequence because force is force.
John
John Holtz, P.E. Global Product Support
Autodesk, Inc. If not provided already, be sure to indicate the version of Inventor Nastran you are using!"The knowledge you seek is at knowledge.autodesk.com" - Confucius 😉
