I am a student using Nastran In Cad to perform a FEA inside Inventor. Both versions are 2018, in case it is relevant.
The analisys to be performed is related with how teeth work. In my case, mandible is constrainted to be fixed (reverse of how it trully works). My problem comes with the maxilla's constraints. I want it to be able only to rotate in Z axis of a coordinate system previously created in the natural axis of rotation, which is not contained in the geometry of the maxilla. The situation is showed in the picture.
There is a remote force applied to the top surface of the maxilla.
Initially, I set a constraint at the maxilla's top face only turning available rotation Rz based on the coordinate system I created, expecting that, due to the remote force, the maxilla closes against the mandible as it is allowed to rotate in that Z axis.
It turns out to be that I do not get it to work. The result is an unstressed geometry except for the face the maxilla constraint is applied. I do not get to know how can I introduce into Nastran in Cad the constraint needed, do I need rigid body connectors?
I hope I gave a decent explanation of my doubts. Thanks in advance for your help and advice
Solved by g.ceruti. Go to Solution.
Hi Pablo,
I think you need to:
Furthermore you need to create some conctact interations between upper and lower teeth, otherwise maxilla would pass throug the mandible.
