Hi there,
I am currently working on a screw connection that is supposed to connect two solid beams. Because there are also transverse forces to be transferred, I have chosen a friction contact between the solids. The connection is affected by transverse forces and bending moments.
Setup (non-linear statics):
Tref: 0K (ALL)
Subcase 1 (5 increments): The screws (beam elements) are "thermally" preloaded (-100Kelvin -->10KN preload on bolt). Works very well!
Subcase 2 (15 increments): The load is initiated here. "thermal preload" remains.
The model is symmetrical in x and z direction and very stable. Solution converges fast.
At first sight the results look ok, but there are two inconsistencies. It looks like the solver applies the load fully and then ramps down incrementally, see the "Applied Load vs Load Scale Factor" - plot below. The result can also be seen when looking at the "Beam axial forces". The displacement of the force application point seems to be ok.
Even if I remove the external load and only want to keep the preload in subcase 2 the results are almost identical:
Subcase 1: Thermal Load
Subcase 2: Thermal Load (same as Sub1 - to "hold" preload).
The plot looks almost identical...
Applied Load vs Load scale Factor (sub1: preload sub2: preload)
Beam axial Force vs Load scale Factor (sub1: preload sub2: preload)
Stettings:
Nastran in CAD 2018
-SLINESLIDETYPE: DYNAMIC and STATIC tested. Static gives bad results. (Quick question: When i expect large sliding, should i use dynamic?)
-WARNINGS: OFF because of the "TRef message: E2..." [i dont know]
I wonder what the problem is.
-Do the results of the intermediate increments have no significance here?
-Is the contact correct defined?
-Why does the "Applied Load vs Load Scale Factor" - plot have a peak.
Does anyone have an idea?
Thank you!
Alex
