Hi @nzaem1992
First, Inventor Stress Analysis does not perform a buckling analysis, does it? You can perform a buckling analysis in Inventor Nastran though.
The differences are as follows:
- Linear stress calculates stress and displacement due to the applied loads. It does not give any indication if the model will buckle or not.
- Buckling calculates how much load is required to cause the model to buckle.
For a model like your tower, I would think that you need to check both. You will use the stress results to decide if they are above the allowable (according to whatever building code you are using for the structure). The building code may not include a buckling check. Since buckling can occur at loads (and therefore stresses) that are lower than the allowable, the structure should be checked for buckling.
John Holtz, P.E. Global Product Support
Autodesk, Inc. If not provided, indicate the version of Inventor Nastran you are using.If the issue is related to a model, attach the model! See What files to provide when the model is needed.
