Linear Buckling with Prestress
darrenlovesmusic
darrenlovesmusic
How can I perform a linear buckling eigenvalue solution with a prestressed model? (Nastran In_CAD 2018) The pre-stress is 14 psi (external) with a second load of 10 psi.
Thank you.
@John_Holtz Is there documentation for STATSUB case control for the 2018 version?
g.ceruti
Hi @darrenlovesmusic ,
I think you have to perform two buckling analysis, because Nastran Incad manages only one loadcase at time.
However,  linear buckling analysis provides eigenvalues which are load multiplyer, so if:
  • conatraints do not change form Step1 to Step 2
  • pressure loads are applied on the same surfaces in both Steps
the eigenvalues of Step 1 results 1.4 times (14/10 psi) those of Step 2 analysis
darrenlovesmusic
@g.ceruti , is it possible to superimpose an known eigenvalue displacement from a linear buckling analysis onto a nonlinear buckling analysis?
g.ceruti
I think there is a method to export the displacement result into a text file, than you have to edit the nastran input file to use it as new node position (but then you have to perform the analysis outside the Inventor Nastran ambient)
Try to read this:
https://forums.autodesk.com/t5/inventor-nastran-forum/nonlinear-buckling-imperfection-from-linear-bu...
I'm not sure, (so you have to verify, or maybe someone can confirm or not) a nonlinear buckling analysis performs a linear buckling analysis using the model updated stiffness resulting from the nonlinear static subcase, and not the initial indeformed model stiffness as a simple linear buckling analysis does.
darrenlovesmusic
@g.ceruti  Yes, I read the question, but I guess its very complicated. Meanwhile, Inventor will take only one subcase for buckling, which is a true bottleneck. I hope this might be something to consider for future releases.
Type a product name
______
icon-svg-close-thick
Cookie preferences
THIRD PARTY SERVICES
icon-svg-hide-thick
icon-svg-show-thick
Qualtrics
Akamai mPulse
Digital River
Dynatrace
Khoros
Launch Darkly
New Relic
Salesforce Live Agent
Wistia
Tealium
Upsellit
CJ Affiliates
Commission Factory
Typepad Stats
Geo Targetly
SpeedCurve
Qualified
icon-svg-hide-thick
icon-svg-show-thick
Google Optimize
ClickTale
OneSignal
Optimizely
Amplitude
Snowplow
UserVoice
Clearbit
YouTube
icon-svg-hide-thick
icon-svg-show-thick
Adobe Analytics
AdWords
Marketo
Doubleclick
HubSpot
Twitter
Facebook
LinkedIn
Yahoo! Japan
Naver
Quantcast
Call Tracking
Wunderkind
ADC Media
AgrantSEM
Bidtellect
Bing
G2Crowd
NMPI Display
VK
Adobe Target
Trendkite
Hotjar
6 Sense
Terminus
StackAdapt
The Trade Desk
RollWorks
Your experience. Your choice.
