Internal nodes, stress values
lhintonC3ZNZ
lhintonC3ZNZ
Hi All, I'm trying to run an analysis of a pressurised compartment where I need to probe the part internally.  However I cannot seem to choose an internal node.  It always chooses a node that is not internal.  Am I missing something?
John_Holtz
Autodesk Support
Autodesk Support
Hi @lhintonC3ZNZ
Other than the suggestion to make an assembly so that you can hide parts to see the inside, I am not aware of solution.
John
John Holtz, P.E.
Global Product Support
Autodesk, Inc.
If not provided, indicate the version of Inventor Nastran you are using.
If the issue is related to a model, attach the model! See What files to provide when the model is needed.
lhintonC3ZNZ
Thanks John, however I can clearly see the inside, as per the attached cross sectional views.  I simply cannot choose or select these nodes to probe them.  It seem strange that you cannot probe a node if it's an internal face.
