Inventor Nastran Forum
Welcome to Autodesk’sInventor Nastran Forums. Share your knowledge, ask questions, and explore popular Inventor Nastran topics.
Inertia data issue
6 REPLIES 6
gusi_cl
452 Views, 6 Replies
Inertia data issue
gusi_cl
Hi, I'm trying to compare Inventor IFA and Inventor Nastran doing a simple flexural analysis. Using an idealization of bar, nastran recognize correctly a squared bar but give incorrect data of a aluminium customized profile.
IFA data are correct compared with the supplier's data sheet.
See .PDF attached.
Inertia data issue
See .PDF attached.
Labels (2)
6 REPLIES 6
gusi_cl
in reply to: gusi_cl
gusi_cl
Sorry... I forget that test is performed in Inventor Nastran 2020, version 14.2.0.101
gusi_cl
gusi_cl
The same happen in Inventor 2022 and nastran 2022, version 16.0.0.87. I attach a pack&go in  this last version.
John_Holtz
John_Holtz
Autodesk Support
Autodesk Support
Interesting.
Inventor Nastran is calculating the properties for the hole in the center. (The Nastran results match the Inventor "Region Properties" for the sketch when the circular hole is selected.)
What's the 12.25 x 12.25 square in the sketch? I did not try deleting it, but I wonder if that is causing confusion for Nastran.
John Holtz, P.E.
Global Product Support
If not provided already, be sure to indicate the version of Inventor Nastran you are using!
"The knowledge you seek is at knowledge.autodesk.com" - Confucius 😉
Interesting.
John Holtz, P.E.
gusi_cl
in reply to: John_Holtz
gusi_cl
Hi John, thank you for your answer.
I've tried with another profile and in this case the inertia properties are calculated =0!!!!
Sketch contains only the area for the extrusion
IFA works well....see attached file.
Can you help me?
Can you help me?
John_Holtz
John_Holtz
Autodesk Support
Autodesk Support
Hi @gusi_cl
Please try the suggestions in this article: Custom cross-sectional beam properties are zero, almost zero, not correct or T2002 error while analy....
John Holtz, P.E.
Hi @gusi_cl
John Holtz, P.E.
gusi_cl
gusi_cl
Hi John, I tried with a simplest sketch and the result is good. In the following days I'll try again set the sketch of the profiles more simpler.
Now I'm going to post another thread because I can't be able to set the inertia property Wz in custom profiles.
