Hyperelastic material properties
Hi Team
I was trying to input the material properties from the compression test and it said that for compression test the stress values should be negative. However, when I enter the negative values of stress the error comes up saying Singularity detected.
Any help would be appreciated.
Thanks.
Tarun
Hi
I have attached the model setup, the table for material data entry and the output file for the same in this post.
Also when I increase the number of bisections limit to 100 the computation keeps going and won't progress after the 6 iteration. It keeps coming back from the 6th iteration to 1 and the loop goes on forever.
Thanks.
Tarun
John_Holtz
Autodesk Support
Autodesk Support
Hi @Anonymous
I think stress and strain need to be negative for compression Smiley Wink
Otherwise, there is nothing useful in the static images or log file you provided. You have the model: what is going on with the results?
I suggest that you output the results from all time steps. ("Nonlinear Setup  1 > Intermediate Results > On".) Has the strain exceeded your stress-strain curve (and therefore is it "extrapolating" to what?). Is something else going wrong that would explain why it cannot continue beyond 80%? Is there a hollow space in your model that you image doesn't show, and that is causing problems?
John Holtz, P.E.
Global Product Support
Autodesk, Inc.
If not provided, indicate the version of Inventor Nastran you are using.
If the issue is related to a model, attach the model! See What files to provide when the model is needed.
Hi @John_Holtz
Thanks for coming back to me.
The geometry is 1/8 of the model and I have applied symmetry conditions to all sides.
Using the negative data it was showing me singularity error.
Well, I don't completely understand what you are saying. I am attaching the model and the data for further investigation.
Tarun
John_Holtz
Autodesk Support
Autodesk Support
Hi @Anonymous
I think you should talk with a hyperelastic material expert, someone who has practical experience. But I do not know who that would be. The questions that come to my mind about your analysis are things like this:
  1. The calculated stress (at 81.5% load) is 41.788 MPa. The stress-strain data goes up to 17 MPa. What data is it using to get to 41 MPa?
  2. I think Mooney Rivlin creates a parabolic stress-strain curve from the material data. The Neo-Hookean model that you are using may be parabolic, or maybe just a straight light. I cannot image that either one is a good fit to your data! I think you need to use a higher order sub type (Yeoh? Polynomial?).
  3. You only have simple tension/compression data. That may be sufficient for the simple tension test you are doing now, but I assume that you want to do something that is more complex. Once the analysis starts to have shear and other effects, I think you are going to need to have additional material data.
John Holtz, P.E.
Autodesk, Inc.
Hi @John_Holtz
Thank you for the feedback. I'll investigate the issue further.
Tarun
