How to customize a scratch folder for Nastran?
iortiz
iortiz
Hi all,
How can be customized, a default SCRATCH folder on Nastran In CAD and Autodesk Nastran?
I want to solve and get the result files on a specific local folder. For example, C:\Users\iortiz\Documents\000_Scratch_CAE
Regards, Igor.
Regards.
Andrew.Sartorelli
Hi Igor,
The scratch folder is defined by the FILESPEC parameter, by default this is C:\ProgramData\Autodesk\Nastran In-CAD 2016\Nastran\Temp but you can change it to whatever you desire. If you want to change it for all future analysis it may be good to go into C:\Program Files\Autodesk\Nastran In-CAD 2016\System\Nastran and change the Nastran.INI file directly.
Andrew
Andrew Sartorelli - Autodesk GmbH
iortiz
Could you give me an example of the rute change on this NASTRAN.INI file?
I have uploaded the .INI file.
Regards.
Andrew.Sartorelli
Hi Igor,
On line 85 you should see FILESPEC=C:\ProgramData\Autodesk\Nastran In-CAD 2016\Nastran\Temp, you can replace that with FILESPEC=C:\Users\iortiz\Documents\000_Scratch_CAE.
Andrew
