How to create a submodel?
PierreMalouf8976
PierreMalouf8976
Is it possible to create a sub-model of a specific component from a half-model, along with its corresponding temperatures, and then perform a non-linear stress analysis on the component?
For background information, I am conducting a non-linear thermal analysis with the aim of assessing the stress / deformation of a particular component within the assembly.
So far I have created a half-model of the mechanism to be evaluated and obtained realistic temperature results.
Analyzing the non-linear stress of the entire half-model  based on the temperature distribution takes a long time. It is also very laborious.
Having the ability to create a sub-model would speed up the process, which is the reason for my initial inquiry.
The only other option would be to create a separate FEA model of the component and manually enter the temperatures based on the half-model. This is something I am trying to avoid.
Best regards,
Pierre Malouf
Consulting mechanical engineer-railway rolling stock
roman.gebhard5MV47
As far as i know, Inventor Nastran has not the capability to create a submodel.
I created a manual way myself for submodelling in Inventor Nastran, but this wont be efficient at all.
The model i created was just for testing. if you are still interested, let me know!
PierreMalouf8976
I agree with you that Nastran lacks the ability to create a submodel. It would be good if this feature was added to Nastran.
I was able to find a workaround for the analysis I am doing. It involves solving a half-model of the system and then transferring the results to a smaller model. More specifically,
1. A nonlinear transient heat analysis is done on the half model.
2. The temperatures for the submodel are taken from step 1 (basically written down on a piece of paper).
3. The submodel is partitioned in smaller sections to which a temperature is assigned and a linear thermal analysis is done. The assigned temperature is based on the results of step 1.
4. The linear thermal analysis of step 3 assigns temperature values to the individual nodes of the submodel.
5. The analysis of step 4 is duplicated and used to run a nonlinear static analysis. Boundary conditions are assigned to represent conditions from the half model and the temperatures of step 4 are used as an input.
6. This allows me to obtain the stress distribution when the submodel is heated.
As you can see, it is labor-intensive.
I would be curious to know how you proceeded.
Best regards,
Pierre Malouf
John_Holtz
Autodesk Support
Autodesk Support
Hi Pierre,
I agree with your steps.
When Nastran uses the temperatures from a heat transfer analysis as a load in a stress analysis, the temperature are transferred from node 1 in the thermal model to node 1 in the stress model, node 2 to node 2, through node N (in whichever model has fewer nodes). Therefore, the thermal model and the stress model need to have the same mesh.
John
John Holtz, P.E.
Global Product Support
Autodesk, Inc.
If not provided, indicate the version of Inventor Nastran you are using.
If the issue is related to a model, attach the model! See What files to provide when the model is needed.
