How to connect a mid-surfaced shell element to a solid element
Hi guys,
As titled, I believe the solution for me lies in rigid body connectors however I don't think using points is sufficient (that or mid-surface everything). I have a large model in which has multiple thin bodies of long lengths, and I would like to maintain some solid surfaces such as end plates as it is a structure. It seems nastran is in agreement as it leaves them as solids when I run 'find thin bodies'. If I mesh the whole assembly as a solid at a relatively ok mesh, I get 5.5 million nodes. What I have done so far is I have taken one of the main assembly sub-assemblies, and turned it into a simplified model with solid bodies in tact, this seemingly decreased the time to create mid-surfaces. Now, when attempting to run the test on this sub-assembly, it gives me a 5004 error which means I am not getting that solid to shell element connection I need.
This is Nastran 2022
It would be fantastic if someone could help me out with some insight into how to best go about solving this.
Cheers
Sub assembly is as below
