I am trying to calculate the stress in four beams which are connected by a couple of axles. The beams are arranged in a scissor formation, as seen in the picture below.
The left corner is constrained in every direction but Ry (so it can rotate around the axle). This is done by making a rigid body from the centre of the hole to the outside of the hole (all the dependent entities are checked) . At the same centre, a constrain is placed where all dependent entities but the Ry are checked.
The right bottom corner is constrained in the same way, the only difference is that this corner can also move in the X-direction. So Tx is also unchecked.
The top two corners both have a bearing load on the face of the hole, as shown in the picture below:
The real problem occures at the connections between the four beams. At the centres of the beams (where they connect), I placed a Beam element from 10 mm long (the beam itself it 200 mm). From this beam element, i made a Rigid body to the beam it was placed on. On this beam, the rigid body was fully constrained. From this same beam element, i made a rigid body to the beam next to it. This beam was fully constrained, but in the Y rotation.
The mesh is set to 20 mm and all the contacts are made automaticly.
When I run the simulation, the stress level around the holes are unrealistically high. Where the rest of the beam seems normal. How can i make the constrain so that I will see normal stress levels around the axle points?
Nice description @Anonymous
There is just a couple of minor things that you need to do differently.
If you are doing a linear static analysis, that is all you need to do. If this is a nonlinear, large displacement analysis, then you also need to do something so that the rigid connectors follow the large deformation theory required for large displacements. See this article for details: How to create a pin connection between linkages in Inventor Nastran.
