- Mute
- Permalink
- Report
I am working on a frame generated model and running a static linear test. Well, I intend to except NIC is not proceeding and it is stuck in the "Generating Nastran File" stage for about 40 min. I cut the model in half and used symmetrical constraint then closed the program and ran it again and again. I restarted the workstation and even closed all other programs running in background, NO Luck.
Any thoughts? or Is there any directive in the .INI file to change in order to solve this?
Max H.
Max H.
