Force as parameter
Force as parameter
Force as parameter
Hi
Now I'm fighting with a calculation of non-linear buckling and I have a problem with how to properly declare loads and how to parametrize one dimension.
Length and thickness are constant, but I have to optimize the width of it to achieve a safety factor equal to 1.5.  Loads here are distributed and are equal n=12N/mm so total stress would be equal =12*width/area.  And here comes my question is here an option to make a parametric optimization in Nastran? To make a function of which would describe my force?
Thanks in advance
For parametric studies you have to write your own iLogic rules.
John_Holtz
Autodesk Support
Autodesk Support
Hi @Anonymous
You said the load is constant (12 N/mm) and the thickness is constant. Therefore, the load applied to the analysis is constant: pressure = (12 N/mm)/( t mm thickness) = 12/t N/mm^2. You do not need to use a parameter for the load.
John Holtz, P.E.
Global Product Support
Autodesk, Inc.
If not provided, indicate the version of Inventor Nastran you are using.
If the issue is related to a model, attach the model! See What files to provide when the model is needed.
You're right. Thanks, however, I will also learn Ilogic.
