Inventor Nastran Forum
Welcome to Autodesk’sInventor Nastran Forums. Share your knowledge, ask questions, and explore popular Inventor Nastran topics.
Flat convergence plot - again
7 REPLIES 7
Message 1 of 8
XYZ965
798 Views, 7 Replies
I'm doing a linear static simulation with a convergence plot with Nastran Inventor 2025. The issue is that the plot displays a flat line and it doesn't refine the mesh.
Continues meshing is switched off and converge is include in the simulation, can someone tell me what I'm doing wrong?
I've had this problem on all simple parts that I tried to simulate, for learning purposes only.
Best regards
7 REPLIES 7
Message 2 of 8
hvdgoot
in reply to: XYZ965
Same here in V2525. V2024 however works fine with exact the same parts.
Message 3 of 8
John_Holtz
in reply to: hvdgoot
Thanks for the observation @hvdgoot . One possibility is the initial mesh is different in 2024 than in 2025, and the initial mesh could be a reason no refinement is found.
Does the convergence plot work when starting with a larger mesh size? What about starting with a smaller mesh size?
John
John Holtz, P.E.
Global Product Support
Autodesk, Inc.
If not provided already, be sure to indicate the version of Inventor Nastran you are using!
"The knowledge you seek is at knowledge.autodesk.com" - Confucius 😉
Message 4 of 8
hvdgoot
in reply to: John_Holtz
Hi John,
Thank you for replying.
Using Inventor 2025 incl Nastran 2025 (19006) and changing the mesh size to very large or very small does not give different results. The plotted line remains horizontal.
I was just tinkering with a simple content center beam (DIN 1025 - I 280-2750) to compare the results between Inventor 2024 with Nastran 2024.
I find it really strange why the 2024 version works great out of the box.
Message 5 of 8
John_Holtz
Thanks for the information @hvdgoot about the difference between Inventor Nastran 2024 and 2025. I just received two examples through a support case that demonstrates the difference. I have sent the models to the development team.
John
John Holtz, P.E.
Autodesk, Inc.
Message 6 of 8
hvdgoot
Hi John,
Any updates as to why 2024 works flawless and 2025 does noet (in my case)?
Kind regads,
Haico
Message 7 of 8
John_Holtz
Sorry, there are no updates to report.
John
John Holtz, P.E.
Autodesk, Inc.
Message 8 of 8
diego.rusnighi
Hi John, I reopened the case...
