Hello everyone,
I am performing an Linear Static analysis for a bus prototype which contains lots of big and small parts with different materials. After running the simulation I am not getting any warning only a Fatal error E5000 (Singularity detected). I have tried various solutions as mentioned in forum like:
1. Check material properties
2. Run the simulation with modal analysis to find out the distorted part (distorted part should be highligted in colour but I am not getting any coloured area.)
3. Remove the value of G from the properties.
i have tried all these ways but couldnt avoid E5000. I am using mostly aluminium and steel as the materials but there is one rubber material is also used with low youngs modulus resulting lower value of G. Is it the one which is causing the Error? I am not pretty sure. If yes, how could i proceed without removing that material?
Thank you
