Does Nastran In-CAD has a tool similar to "Make FEM", available in Simulation Mechanical?
I need to use a buckled shape as input for strees analysis.
Solved by Andrew.Sartorelli. Go to Solution.
Hi @Anonymous,
It is not possible to export the deformed mesh from a Nastran In-CAD analysis to be used in another Nastran In-CAD analysis. For non-linear static analyses subcases will act as a continuation from the previous subcase by default. When this behavior is not desired the NLSUBCREINIT parameter can be turned on.
Best Regards,
Andrew
______________________________________________________________
If my post answers your question, please click the "Accept as Solution" button. This helps everyone find answers more quickly!
