Error T2025 using Variable Load
Daniel.Bonavita
Daniel.Bonavita
I have been having a weird phenomena where I will run a static analysis and obtain results, then when I tweak parameters and try to run the analysis again I get the fatal error T2025. This error is apparently tied to the model coordinates, but I don't know how to find the coordinates in question or how to prevent this from happening.
It also seems that this could be related to the variable loads that I am applying on my assembly, as the problem appears to only happen after a successful run using variable loads.
Has anyone run into this before or know how to fix T2025 errors?
Daniel Bonavita
Design Engineer
John_Holtz
Autodesk Support
Autodesk Support
Hi @Daniel.Bonavita
What is a T2025 error? I have not encountered it before.
What "parameters" are you changing? Maybe that will provide a clue about the problem.
Given the unknown nature of the problem, you may need to zip the assembly (.iam files) and part (.ipt files) files and post them to the forum.
John Holtz, P.E.
Global Product Support
Autodesk, Inc.
If not provided, indicate the version of Inventor Nastran you are using.
If the issue is related to a model, attach the model! See What files to provide when the model is needed.
