displacement Boundary condition in Nastran
I have a thin cantilever slab. Thickness = 0.5 mm, Length  =40mm, width = 20mm
I would like to press/push the free end / edge by 2 mm.
I don't want to use pressure or Force boundary condition.
Would you please suggest me which existing boundary condition in Autodesk Inventor Nastran 2020 could I use.
Thanks a lot in advance.
Cheers,
Sivam
John_Holtz
Autodesk Support
Autodesk Support
Hi Sivam. Welcome to the Inventor Nastran forum.
You need to look under loads: Enforced Motion > Displacement and apply it to the end of the model.
Be sure to add a Constraint to the same geometry and "fixed" in the same direction and the enforced motion. The enforced motion moves the constraint, and the constraint moves the model.
John Holtz, P.E.
Global Product Support
Autodesk, Inc.
If not provided, indicate the version of Inventor Nastran you are using.
If the issue is related to a model, attach the model! See What files to provide when the model is needed.
Dear John,
Very helpful.
This video was also helpful, Particularly at 4:02 and 5:25
https://www.youtube.com/watch?v=icw7HdAfuDY
I summarized the steps.
Cheers,
Sivam
Apply enforced motionApply enforced motionAdd constraintAdd constraint
Displaying BC and its constraint togetherDisplaying BC and its constraint together
Solver Ran and displaying resultsSolver Ran and displaying results
