Damage plot Vibration Fatigue
viktor_velichko
viktor_velichko
Hello colleagues! I am doing a vibration analysis of fatigue. And I see that damage and life are displayed unrealistic. What am I doing wrong? I followed the recommendations in the attached files. RMS Stress Fatigue.jpgFatigue Damage.jpg
John_Holtz
Autodesk Support
Autodesk Support
Hi @viktor_velichko
The short answer is the "Fatigue Setup > Event Duration" is missing. The software needs to know "how long the vibration is" so that it can convert the calculated damage to a calculated life. (Remember that the life shown in Inventor Nastran is in units of time, not the number of cycles.)
Another issue is the results file has 12 fatigue results, 6 of which appear to be reasonable and 6 which appear to be results of 0. Inventor Nastran is showing 9 of the results. Which 9 is it showing? It looks like the "Fatigue > Shell Damage" and "Fatigue > Shell Life" are correct (and maybe some other ones).
John Holtz, P.E.
Global Product Support
Autodesk, Inc.
If not provided, indicate the version of Inventor Nastran you are using.
If the issue is related to a model, attach the model! See What files to provide when the model is needed.
viktor_velichko
"The short answer is the "Fatigue Setup > Event Duration" is missing"
Yes, I missed this step. Thank you!
"It looks like the "Fatigue > Shell Damage" and "Fatigue > Shell Life" are correct (and maybe some other ones)."
It's strange, because in shell usually has different stess level on Top and Bottom face.
