Hi John,
Your image made me realize that I missed a critical point in my description of axisymmetric versus cyclic symmetry. (I updated my original reply to include this information, too)
In axisymmetric, or regular symmetry, the nodes cannot displace off of the symmetry plane. They can only displace in the symmetry plane.
Cyclic "symmetry" is misleading in that the displacements are not symmetric (mirror-image) about the symmetry plane. The nodes can displace off of the "symmetry" plane, but the corresponding node on the other "plane" displaces in the same direction, the same magnitude. Some other terminology is probably more accurate for this than "cyclic symmetry". Maybe "periodic" meaning that it repeats.
So in your case, are the displacements mirrored about the symmetry planes? If so, you can use symmetry constraints and perform the analysis in In-CAD. If they are periodic ("cyclic symmetry"), then you cannot perform the analysis in In-CAD.
John Holtz, P.E. Global Product Support
Autodesk, Inc. If not provided, indicate the version of Inventor Nastran you are using.If the issue is related to a model, attach the model! See What files to provide when the model is needed.
