Hi @Anonymous,
It took a while to sort out all of the issues, but I think that it works now. (Of course, my constraints may not be 100% correct because I am not that familiar with your model and the intent.)
The original discussion was for a complete cylinder with no slices (Figure 1), so symmetry constraints would be used regardless of where the full model is cut to create a symmetry model.
Figure 1: Model in original post
I do not know how to describe the new model (Figure 2), but I would say it is a cylinder but with 12 slices or saw cuts through 98% of the length. If you make a symmetry plane through the middle of a saw cut, you do not put symmetry constraints on the saw cut face; you only put symmetry constraints on the 2% of the length that is sliced by the symmetry plane. In the first model attached to this thread, you had the symmetry constraints applied to the full length, and that was the mistake.
Figure 2: Model in this post
In your second model attached to this post, you are holding small end of the locking sleeve in the axial direction, and trying to move it on the two side faces. Naturally, it will not move very well if you pull at one location and hold it at another! You need to put the axial constraints (Z direction in the local coordinate system) on the same faces where you have the enforced motion. (The enforced motions move the constraints, and the constraints move the model.) You may need hoop symmetry constraints on the two sides of the locking sleeve also. (I assume the locking sleeve is a full ring without any saw cuts.)
The next problem is that you need to specify a maximum activation distance for the separation contact. Since you are trying to move the locking ring 10 mm, you need to create enough contact elements to cover that distance, plus a little extra to extend to the next node. So a maximum activation distance of 15 is about right.
The last problem is with the mesh. For some reason, it passes through the body. That is why the mesh is not visible in some locations. (If you look at the results, you will see that the mesh on the collet is incorrect.) I corrected this problem by rebuilding and updating the mass in Inventor. ("Manage > Update > Rebuild All" and "Update Mass")
With those changes (and I think I changed a few nonlinear setup input), the analysis runs. See the attached file "2S_90_025 model 02.iam.zip". (I tried 3 variations: with and without friction, and with and without nonlinear materials. I was not sure what effect was preventing the analysis from completing, but it turned out to be the maximum activation distance.)
John Holtz, P.E. Global Product Support
Autodesk, Inc. If not provided already, be sure to indicate the version of Inventor Nastran you are using!"The knowledge you seek is at knowledge.autodesk.com" - Confucius 😉
