Inventor Nastran Forum
Welcome to Autodesk’sInventor Nastran Forums. Share your knowledge, ask questions, and explore popular Inventor Nastran topics.
Crashing when trying to create finer mesh
2 REPLIES 2
T3H
652 Views, 2 Replies
The attached part crashes when I try to mesh it with a smaller element size. When I set the element size to 8mm it meshes fine, 7mm or below it crashes every time. I'm using version 2018.2.1.428. Any ideas? Thanks.
2 REPLIES 2
John_Holtz
in reply to: T3H
Hi @T3H
I used the suggestions in this article to diagnose the problem: Nastran In-CAD: Mesh fails at small element size. By splitting the faces of the model, the mesh will succeed at smaller mesh sizes.
Mesh with original modelMesh with original model
Mesh after splitting facesMesh after splitting faces
The feature in common between your model and the example in the article is that both models have a lot of holes. Maybe that is significant? I will mention this to the developers.
John Holtz, P.E.
Global Product Support
If not provided already, be sure to indicate the version of Inventor Nastran you are using!
"The knowledge you seek is at knowledge.autodesk.com" - Confucius 😉
T3H
in reply to: John_Holtz
That is really strange, but it works. Thank you!
