Greetings all
I'm performing static analysis and I'm trying to add a convergence plot and I did tick the include in the analysis check but it still doesn't perform the convergence and the plot is empty.
File attached
Solved by benoit.neu-faber. Go to Solution.
Hi @s201507170
I had a look to your model.
First of all I would suggest you o have a look to the attached file.
I changed the constraints :
- removed the frictionless
- ticked the axial direction in the pin constraints.
I made some changes in the mesh and convergence settings. Be sure you check the box add to the analysis in the convergence settings.
Hope this helps.
Please accept solution and give likes if applicable
Benoit Neu-Faber
INNOSIM https://servicesmarketplace.autodesk.com/provider/public/innosim
Autodesk Service Provider / CFD-Nastran Trainer
https://www.linkedin.com/in/benoit-neu-faber/
