05:04 PM
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
Hello, I am new to nastran FEA. I am doing a test run on a welded assembly of 2 tubes and a gusset plate. Forces are simply pulling the ends apart, 10 lb in either direction. Constraints are: point nearest gusset is fixed, endpoints where the force is applied is constrained to have no rotation and no translation in Y. The tubes are meshed as beam elements, the gusset is meshed as solid. I am getting E5000 Singularity detected at grid 4347 component 3.
See images
I am thinking it is probably the contact between the gusset plate and the tubes. How do I do that? Is it a surface contact?
