Inventor Nastran Forum
Welcome to Autodesk’sInventor Nastran Forums. Share your knowledge, ask questions, and explore popular Inventor Nastran topics.
Column profile with base plate analysis
4 REPLIES 4
algpi
778 Views, 4 Replies
algpi
Dears,
I've got question to You, regarding one direction constraint.
In attachment column profile with base plate where I would like to add constraint in Y(-) direction only to plate.
This will reprezent some e.g. concrete, steel base, etc..
I don't want to model any base and adding contact between base plate and it.
I would like to simply add some constrain / connector to base plate with e.g. stiffnes only in one direction e.g. Y(-), and Y(+) have free to move.
Constraint what I'm looking for I've got found in Frame Analysis (custom constraint), please see attachment.
Is it posible to do it in NiC?
Thank You in advance for Your help
Best Regards
Maciej
Dears,
Best Regards
Maciej
4 REPLIES 4
John_Holtz
in reply to: algpi
John_Holtz
Autodesk Support
Autodesk Support
Hi Maciej,
The Nastran solver does have gap elements (CGAP and PGAP cards in the .nas file), but Inventor Nastran/Nastran InCAD does not have a method of creating those elements. So Inventor Nastran/Nastran InCAD does not have the equivalent of a 1 way constraint.
Here are your options:
  1. If you have Nastran In-CAD 2019 or Inventor Nastran 2020, you should have the Nastran Editor. In theory, you can modify the .nas file and add gap elements to create the one-way constraint.
  2. Model a slab (make it a 1 element shell part) and define separation contact.
  3. Ignore the effects and keep the analysis the way you have it.
John Holtz, P.E.
Global Product Support
Autodesk, Inc.
If not provided already, be sure to indicate the version of Inventor Nastran you are using!
"The knowledge you seek is at knowledge.autodesk.com" - Confucius 😉
Hi Maciej,
John Holtz, P.E.
Autodesk, Inc.
algpi
in reply to: John_Holtz
algpi
Thank You John
Thank You John
rlkillian
in reply to: algpi
rlkillian
This is something I feel is need very badly. Please go here and vote for it. Thanks for posting this.
ken.friesen
ken.friesen
DELETED.
DELETED.
