I am currently just a student doing my Master's in Computational Material Science . Previously when I used to work I was working in Inventor Nastran doing some projects like Nonlinear Transient Response test and in my local machine I used to control the number of threads to run the analysis. For this kind of parallelization I would like to know what is happening behind the scene for parallelization .
1. Are there any openMP or MPI functionalities in the code which can go this parallelization?
2. Can the analysis be run on a HPC (High performance computing - Distributed server) ?
Looking forward for some reply .
Solved by John_Holtz. Go to Solution.
Hi @Aadithya01
Good luck with your degree.
Hi @Aadithya01
