Hi everyone,
I've attached an assembly with two problems I cannot figure out and would appreciate some help.
I'm running Inventor 2021.2.2 and Inventor Nastran 2021.2.0.493
1. When I click run I get the error "Could not find a valid FE Mesh, Please Update FE mesh and Try again!" repeated 4 times, and then it runs normally. I cannot seem to get a good answer from the forums on how to solve this, the one answer I could find is to suppress components one by one which is a ridiculous solution procedure.
2. The solution fails due to a problem with Contacts 18 and 19. If I suppress those, it solves - but I cannot figure out what the issue is with those contacts.
Any help is appreciated.
As a side note, with assemblies like this with frames it is mega annoying that every time I tweak the frame, Inventor nastran re-assigns all the members that changed from solid to beam - and then I have to change it back, research contacts, etc. Could someone get that on a just do it list please? (sometimes it is nice to have the functionality, but rather than wrapping it up in environment initialization, instead add a manually activated function?)
Hi @imajar ,
I am unable to solve your problem, but I want to respond to your "side note".
Have you ever thought about a different approach when you want to use Frame Generator and not use Line elements in Nastran? You could build a Derive Part with Multi Bodies and than recreate your assembly using the Make Components workflow. In that case you still can use Frame Generator and keep your analysis geometry up-to-date. See the video below.
Hi @Roelof.Feijen,
I very much appreciate the time you took to demonstrate the workflow! That does look like a good way to analyze frame models.
Meanwhile if anyone knows how to resolve the original issues I mentioned it would be appreciated just so that I can troubleshoot things better in the future.
Hi @imajar,
I did not check your model but regarding your item #1, I consider this to be a really annoying error that is sometimes very difficult to debug. A few days back I found it may be caused by too coarse mesh in some locations of the model. Imagine that a load/constraint is applied to some edge but the mesh is shifted sideways because it's not refined enough.
Another reason may be that you mixed your simulation geometry and some construction/auxiliary geometry (i.e. two lines or points at the same location with the load/constraint applied to an incorrect entity).
Martin M.
