Can't select multiple bodies
Jerry_Smith
Jerry_Smith
No way to select multiple bodies (not surfaces, vertexs, edges, etc.) for a explicit dynamics analysis load.
It's a large assembly, and I don't want every object selected; just the solid bodies. I can do this by selecting one at a time; however, there seems to be no way to select multiple solid bodies at the same time.
Doesn't matter which file I open.
In large assemblies, this multiplies the workload greatly and makes our engineers doing this analysis unaffordable.
John_Holtz
Autodesk Support
Autodesk Support
Hi @Jerry_Smith
Let me know if this is what you are asking for.
  • When applying a load, you can right-click in the Selected Entities box and choose a filter to Select Faces, etc. For some loads that make sense to apply to bodies, such as initial velocity, internal heat generated, etc, it makes sense to have a filter for "Select Bodies", such as shown below.
  • If that filter existed, it would be easier to select the bodies by clicking or by using a rectangle selection.
John
John Holtz, P.E.
Global Product Support
Autodesk, Inc.
If not provided, indicate the version of Inventor Nastran you are using.
If the issue is related to a model, attach the model! See What files to provide when the model is needed.
Jerry_Smith
That is EXACTLY what I'm asking for!!
Can we make this happen?
John_Holtz
Autodesk Support
Autodesk Support
I will ask.
John Holtz, P.E.
Autodesk, Inc.
