Inventor Nastran Forum
Welcome to Autodesk’sInventor Nastran Forums. Share your knowledge, ask questions, and explore popular Inventor Nastran topics.
bolt connector simulations
1 REPLY 1
yta10
462 Views, 1 Reply
Hello
I used bolt connector to simulate to see the stress in the bolts and the parts, when lifting the gray part up.
but I don't see any stress result in the bolts..
Could anyone help me with this?
Thank you
1 REPLY 1
John_Holtz
in reply to: yta10
Instead of looking at the SOLID stress result, try looking at the BEAM stress result. Bolts are simulated using Beam elements, so the results related to them are listed under Beam.
(There are also BAR results listed. The head and nut of the bolt are analyzed using bar elements. But the bar elements are not shown on the model, so you cannot see those results.)
John Holtz, P.E.
Global Product Support
If not provided already, be sure to indicate the version of Inventor Nastran you are using!
"The knowledge you seek is at knowledge.autodesk.com" - Confucius 😉
Technology Administrators
