Another interference fit analysis
Hi All,
There is some great information here on simulating fits, I'm after some help regarding the best workflow for my situation.
I have a cast wheel centre which is supplied with a 90mm bore, I wish to assess the effect of boring out to mount on a 114mm diameter shaft utilizing a 0.1mm interference between shaft and bore. As can be seen in the attached model the centre rim of the wheel has 3-off equi-spaced cut outs and I am particularly interested in the effect of the cut outs under the load applied from the interference fit.
I have used a separation contact between the bore and the shaft with unsymmetric contact penetration type and a maximum activation distance of 0.2mm.
The mesh of these contact surfaces is currently 2mm.
To get even stress distribution from the pressure due to the 0.1mm interference it appears I need a much smaller mesh size - however my PC seems to crash out of the analysis.
I've tried taking a 6o degree "wedge" and apply a radial symmetry based on a cylindrical UCS to reduce model size by 2/3rds however this applied multiple constraint conditions to shared nodes of the shaft so it will not give me a valid solution.
Rather than modelling the interference I tried applying a thermal load to make the shaft expand but I need to research this method further as I could net even get the Nastran file to generate on running the analysis.
Is there any tips anyone could provide to point me in the right direction, also with an efficient simulation set up how long would I expect such a simulation to take with a current midrange i7 CPU +32GB ram (minutes, hours, days??)
Sorry about the long post!
