Inventor Nastran Forum
Welcome to Autodesk’sInventor Nastran Forums. Share your knowledge, ask questions, and explore popular Inventor Nastran topics.
ANALYSIS RESULT IS EXTRAORDINARY HIGH VALUE.
2 REPLIES 2
ma20049Y9RJZ
383 Views, 2 Replies
ma20049Y9RJZ
Observer
Observer
Hello everyone,
I have problem with my result from my analysis where all the value obtained from the result is far beyond typical.
My analysis is to design a wooden chair which are made from oak wood to analyze how it will response in real world
The issue is all the result value are too high from the expected.
For example, the max value for Von Mises Stress = 3793900.00 MPa as well as others result which shown an extraordinary high value in the image attached.
Here I attached some of the image from my analysis result.
Thank you.
Hello everyone,
Thank you.
2 REPLIES 2
John_Holtz
in reply to: ma20049Y9RJZ
John_Holtz
Autodesk Support
Autodesk Support
Hi @ma20049Y9RJZ  Welcome to the Inventor Nastran forum.
Yes, you have parts with very large results and parts with very small results (that is, I am guessing the results are 0 in the other parts).
It is very unusual to have an assembly and to not have contact defined in the model. Please read section 6 in the PDF document attached to my forum post Suggested Reading - Tips and Tricks on the Inventor Nastran forum. Then define contact in the model to bond all the parts of the assembly together.
Let us know if the results are more reasonable.
John
John Holtz, P.E.
Global Product Support
Autodesk, Inc.
If not provided already, be sure to indicate the version of Inventor Nastran you are using!
"The knowledge you seek is at knowledge.autodesk.com" - Confucius 😉
John
John Holtz, P.E.
Autodesk, Inc.
ma20049Y9RJZ
in reply to: John_Holtz
ma20049Y9RJZ
Observer
Observer
Hello @John_Holtz , thank you for your response.
After reading and implementing the tips and tricks that you provided, I finally manage to achieve the expected result within the specified range.
Your guidance was very helpful to solve my issue.
Once again, thank you for your help.
