Agilus 30 Simulation / Enter Custom Material with Hardness
nishan.japahuge
nishan.japahuge
I'm trying to perform linear stress analysis on Agilus 30. Is there any way that  I can enter hardness value to inventor custom material?
Nishan
Gabriel_Watson
You can create new materials in the material editor, edit existing ones, or duplicate those you already have saved to your document:
https://help.autodesk.com/view/INVNTOR/2023/ENU/?guid=GUID-6F090B0A-F28C-4165-A4D2-63C89D086B81
nishan.japahuge
nishan.japahuge
Thanks for the reply. Unfortunately, you have not paid attention to details. I specifically want to add shore hardness value to the custom material. I don't see any way to do that.
Gabriel_Watson
I think you came to the wrong forum.
Try the Inventor Nastran forum for other types of simulation:
https://forums.autodesk.com/t5/inventor-nastran-forum/tool-punch-on-material/td-p/10566397
I have shown you how Inventor does not take shore hardness as an input, now it is up to you how to use that information.
John_Holtz
Autodesk Support
Autodesk Support
Hi @nishan.japahuge
What simulation software are you using?
Most simulation software does not use the hardness value. Basically, you need to determine how the hardness has any effect on the linear stress simulation, most likely convert the hardness value to a material property that is used in a linear stress simulation (if that even exists), and enter the converted value into the material properties.
Note that Inventor Nastran has its own material input dialogs, so it is not strictly necessary to enter all the material properties in the Inventor material dialogs. In fact, there are many material properties for simulation that cannot be entered in the Inventor material library.
John
John Holtz, P.E.
Global Product Support
Autodesk, Inc.
If not provided, indicate the version of Inventor Nastran you are using.
If the issue is related to a model, attach the model! See What files to provide when the model is needed.
