Inventor Nastran Forum
Welcome to Autodesk’sInventor Nastran Forums. Share your knowledge, ask questions, and explore popular Inventor Nastran topics.
Add beam elements to my shell model?
2 REPLIES 2
autodesk428JLG
278 Views, 2 Replies
Hello !
I have a shell model and now i would like to add a wire, modelled with beam elements, to my shell model. What is the best way to go?  I tried to add a line to the part, then i used "insert frame", added my section. Then i opened "nastran" and it automatically added the beam. However, when contraining the node in the end, i got a error message, see below. Does someone has an idea what i missed? The start point of the line in the sketch mode, doesnt that becomes an automatic constrain maybe....
(Im using Nastran In Cad 2019)
2 REPLIES 2
John_Holtz
in reply to: autodesk428JLG
Hi @autodesk428JLG
You made the model one step too complex.
  • Do not use the frame generator to make a simple beam.
  • Use the sketch line to create a beam Idealization in Nastran.
There are multiple things that constraints can be applied to when you use the Frame Generator. The constraint can be applied to the solid (if it is shown; it is normally hidden), it can be applied to the frame member, and it can be applied to the sketch line. In this case, I am guessing the constraint got applied to a point on the sketch line, but the sketch has no mesh associated with it. This would cause the error.
John
John Holtz, P.E.
Global Product Support
If not provided already, be sure to indicate the version of Inventor Nastran you are using!
"The knowledge you seek is at knowledge.autodesk.com" - Confucius 😉
autodesk428JLG
in reply to: John_Holtz
Thank you, John!
