We have a product that uses DocumentEvents.OnChangeSelectSet. After the latest update from 2021 to 2021.1 it stopped working.
The code/event we use to subscribe the event is Application.ApplicationEvents.OnActivateDocument and to unsubscribe the event in Application.ApplicationEvents.OnDeactivateDocument.
The DocumentEvents.OnChangeSelectSet do not always fire after updating Inventor to version 2021.1.
Is there enyone else who has or can reproduce this problem?
The best way to test this is you have an assembly open (not new) and click in the model browser pane several times (Folders, parts, plane etc.) and then move between open files and repeat clicking in the model browser pane or in the modelview.
Sending my example code below.
Example code:
Test class:
public class Test
private Inventor.Application inventorApplication;
public Test()
StandardAddInServer.Instance.Application.ApplicationEvents.OnActivateDocument += ApplicationEvents_OnActivateDocument;
StandardAddInServer.Instance.Application.ApplicationEvents.OnDeactivateDocument += ApplicationEvents_OnDeactivateDocument;
/// <summary>
/// We use this event for unsubscribe the DocumentEvents_OnChangeSelectSet.
/// </summary>
/// <param name="DocumentObject"></param>
/// <param name="BeforeOrAfter"></param>
/// <param name="Context"></param>
/// <param name="HandlingCode"></param>
private void ApplicationEvents_OnDeactivateDocument(_Document DocumentObject, EventTimingEnum BeforeOrAfter, NameValueMap Context, out HandlingCodeEnum HandlingCode)
try
if (BeforeOrAfter == EventTimingEnum.kBefore)
DocumentObject.DocumentEvents.OnChangeSelectSet -= DocumentEvents_OnChangeSelectSet;
catch
HandlingCode = HandlingCodeEnum.kEventNotHandled;
/// <summary>
/// We use this event for subscribe the DocumentEvents_OnChangeSelectSet.
/// </summary>
private void ApplicationEvents_OnActivateDocument(_Document DocumentObject, EventTimingEnum BeforeOrAfter, NameValueMap Context, out HandlingCodeEnum HandlingCode)
try
if (BeforeOrAfter == EventTimingEnum.kAfter)
DocumentObject.DocumentEvents.OnChangeSelectSet += DocumentEvents_OnChangeSelectSet;
MessageBox.Show("Connected!");
catch
/// <summary>
/// Fires on selection change in view or browser. Very Important for our product.
/// </summary>
private void DocumentEvents_OnChangeSelectSet(EventTimingEnum BeforeOrAfter, NameValueMap Context, out HandlingCodeEnum HandlingCode)
MessageBox.Show("Working!");
Modified code in StandardAddinServer class:
public StandardAddInServer()
/// <summary>
/// Get this AddInServer instance
/// </summary>
public static StandardAddInServer Instance
get
return _instance;
/// <summary>
/// </summary>
public Inventor.Application Application
get
return m_inventorApplication;
public void Activate(Inventor.ApplicationAddInSite AddInSiteObject, bool FirstTime)
m_inventorApplication = AddInSiteObject.Application;
_instance = this;
Test testClass = new Test();
I have exactly the same error. The event is not always called. In 2021.0 everything works fine.
Found a solution.
Use local instances.
public class Test
private ApplicationEvents _applicationEvents;
public ApplicationEvents AppEvents
get => _applicationEvents; set => _applicationEvents = value;
public Test()
AppEvents = AddInServer.Instance.Application.ApplicationEvents;
AppEvents.OnActivateDocument += ApplicationEvents_OnActivateDocument;
AppEvents.OnDeactivateDocument += ApplicationEvents_OnDeactivateDocument;
Yes, we solved the problem. The lifetime of the COM-Objects seem to end very short, if they are not a member of a class. In the earlier Versions, those objects had a longer lifetime.
