iLogic code for saving and replacing a part in assembly file
harisali110
harisali110
Hi All,
I am new to iLogic and I am looking to create a code for the following application:
Preface: The user already has a new assembly document open and runs the code to do the following:
  1. iLogic loads a specific 'original' part file in the assembly document
  2. iLogic makes a 'copy' of this part (save as) and prompts the user to enter a new filename for this part and where to save this 'copy' of the part
  3. iLogic then replaces the 'original' with the 'copy'
The general application is that I want to make a library of 'original' parts so that the user can use them in their assembly as a 'copy' to make further modifications to the 'copy' which doesn't affect the 'original' parts in any way.
I've already tried the "Save & Replace" bonus feature in iLogic but as I understand it, you have to select the part in the tree or in the graphics window to proceed with the "Save & Replace" and there is no way around it.
Thanks in advance to all the iLogic experts here for helping me out.
Haris
A.Acheson
Hi @harisali110  welcome to the forum. Here is one method to do this which includes a dialogue box to select the part file, place it at a location in the assembly then saves a new file and replaces the original. Let us know if that works. I have left in notes to describe the functioning to aid in learning.
'Create a new FileDialog object.
    Dim FileDlg As Inventor.FileDialog
  	ThisApplication.CreateFileDialog(FileDlg)
    'Define the filter to select part and assembly files or any file.
    FileDlg.Filter = "Inventor Files (*.ipt)|*.ipt|All Files (*.*)|*.*"
    'Set the title for the dialog.
    FileDlg.DialogTitle = "Save Copy As Utility"
    'Set the initial directory that will be displayed in the dialog.
    FileDlg.InitialDirectory = "C:\Users\Enter Name Here"
	FileDlg.ShowOpen
	'Deal with a canceled file Selection
 	If FileDlg.FileName = Nothing  Then Return
    'Set a reference to the assembly component definintion.
    Dim AsmCompDef As AssemblyComponentDefinition = ThisApplication.ActiveDocument.ComponentDefinition
	'Post the filename To the Private Event queue.
   	ThisApplication.CommandManager.PostPrivateEvent(Inventor.PrivateEventTypeEnum.kFileNameEvent, FileDlg.FileName)
	'Get the control definition for the Place Component command.
    Dim ctrlDef As Inventor.ControlDefinition = ThisApplication.CommandManager.ControlDefinitions.Item("AssemblyPlaceComponentCmd")
	'Execute the command.
    ctrlDef.Execute2(True)
For Each Occ As ComponentOccurrence In AsmCompDef.Occurrences
	If Occ.Definition.Document.FullFileName = FileDlg.FileName Then
		'Select the occurrence just added
		ThisApplication.CommandManager.DoSelect(Occ)
	End If
Next
'Get the command (Button in the productivity tab)
ctrlDef = ThisApplication.CommandManager.ControlDefinitions.Item("AssemblyBonusTools_SaveAndReplaceComponentCmd")
ctrlDef.Execute()
Regards
Alan
harisali110
@A.Acheson Thanks! This is basically what I am looking for. I can play around with this now to get a suitable format.
e2000773
How would this be modified to work with ”place from vault”- filedialog? Is there any way?
