Rule to measure an edge and asign to a parameter
kostremEEC7J
kostremEEC7J
So I set up a rule to select a face of an object and export the area of the face to a parameter. I would like to do something similar except I want to measure an edge of a part, and export that selected length as a parameter. I am unable to figure out what code I need to export the measured distance of an edge select.
I figured this was the code I needed to select the edge but I don't know how to get that to a parameter:
ThisApplication.CommandManager.Pick(SelectionfilterEnum.kPartEdgeFilter, "Length_1")
I am extremely novice when it come to writing ilogic rules and code. I can take something someone else has wrote and manipulate it to do what I want closely but I fail often writing from scratch. Any pointers or well written guides you can direct me to with common code templates etc.?
Thank you.
dalton98
The easiest way to do this would be to use the measure tool. See below code. I tried to comment my thought process when writing it
'find the object type of the selected part
'it returned a number so look up that number
'inventor top right (?) icon -> programming/api help -> search the number
'test = ThisApplication.CommandManager.Pick(SelectionFilterEnum.kPartEdgeFilter, "Length_1")
'MessageBox.Show(test.Type.ToString)
'the selection was and Edge or EdgeProxy in assembly enviroment
Dim oEdge As EdgeProxy = ThisApplication.CommandManager.Pick(SelectionFilterEnum.kPartEdgeFilter, "Length_1")
'measure tool using the start and end point of the edge
Dim oLength As Double = ThisApplication.MeasureTools.GetMinimumDistance(oEdge.StartVertex.Point, oEdge.StopVertex.Point)
'i used 'Document' so it would work for 'PartDocument' and 'AssemblyDocument' Dim oDoc As Document = ThisDoc.Document Dim oUserParams As UserParameters = oDoc.ComponentDefinition.Parameters.UserParameters Dim oUserParam As UserParameter
'try to get user parameter "Length_1"
'if it fails then create that parameter with the Catch Try oUserParam = oUserParams.Item("Length_1") Catch oUserParam = oUserParams.AddByValue("Length_1", oLength, UnitsTypeEnum.kInchLengthUnits) End Try
kostremEEC7J
@dalton98I used that rule and I couldn't get it to work. It gives me an error which I'll attach. Regardless I appreciate your efforts.
dalton98
What is on line 10? If its "Dim oEdge As EdgeProxy = ...." you would have to use "Dim oEdge as Edge" for a part document. Or just leave out the As Object "Dim oEdge = ...."
