I determined the properties of the helical curve in the model to be a thin line and black.
When I export it to pdf, it was green line.
How can I change it to black?
Gali
Gali
Are you trying to export directly from the part or assembly environment?
Have you tried to export from the drawing environment?
From drawing to export and then go to options you can set the color to black as in the following image
Sergio Daniel Suarez
Mechanical Designer
| Upwork Profile | LinkedIn
Mechanical Designer
Thank you for your reply.
I exported it in part environment (3D PDF)
I attached the screenshot.
And by the way I couldn't attach my part to drawing.
