Getting thumbnail from Active Document to show in PictureBox VB.Net
I'm trying to get the thumbnail to show in a picture box.
I did some research and found this code from the Mod Machine guys, but i'm getting an error. System.Runtime.InteropServices.COMException: 'Catastrophic failure (Exception from HRESULT: 0x8000FFFF (E_UNEXPECTED))' on this line of code "thumbnail = thumbProp.value"
Sample Code
Public Sub WriteThumbnail()
        Dim oDoc3 As Document
        oDoc3 = ThisApplication.ActiveDocument
        Dim oPropSet3 As PropertySet
        oPropSet3 = oDoc3.PropertySets.Item("Inventor Summary Information")
        Dim thumbProp As Inventor.Property = oPropSet3.Item("Thumbnail")
        Dim thumbnail As stdole.IPictureDisp
        thumbnail = thumbProp.value 'Error Here
        Try
            PictureBox4.Image = thumbnail
        Catch ex As Exception
        End Try
    End Sub
Jef_E
Try it like this
Imports Inventor
Imports Microsoft.VisualBasic
Public Class Form1
   Private Sub Button1_Click(ByVal sender As System.Object, _
                ByVal e As System.EventArgs) Handles Button1.Click
      ' Create an instance of Apprentice.
      Dim apprentice As New ApprenticeServerComponent
      ' Open a document.
      Dim doc As ApprenticeServerDocument
      doc = apprentice.Open("C:\Temp\Part1.ipt")
      ' Get the Summary Information property set.
      Dim summaryInfo As PropertySet
      summaryInfo = doc.PropertySets.Item( _
      ' Get the thumbnail property.
      thumbProp = summaryInfo.Item("Thumbnail")
      ' Get the thumbnail image.
      thumbnail = thumbProp.Value
      ' Convert the IPictureDisp object to an Image.
      Dim img As Image = _
                    Compatibility.VB6.IPictureDispToImage(thumbnail)
      ' Display the image in the picture box.
      PictureBox1.Image = img
   End Sub
End Class
Code source from this blog post
http://modthemachine.typepad.com/my_weblog/2010/06/accessing-thumbnail-images.html
Please kudo if this post was helpfull
Please accept as solution if your problem was solved
Inventor 2014 SP2
It says this line of code is obsolete
Dim img As Image = Compatibility.VB6.IPictureDispToImage(thumbnail)
I just had to change my framework to 4 and it worked.
