Create AutoBallons
Create AutoBallons
Ruffy85
Message 1 of 1
Create AutoBallons
Ruffy85
How to change this code for multiple items in selectset with compare function that a part will not be multiple times balloned? like the standard function "Auto Ballooning" in inventor?
Thanks for help
Public Sub CreateBalloon()
    ' Set a reference to the drawing document.
    ' This assumes a drawing document is active.
    Dim oDrawDoc As DrawingDocument
    Set oDrawDoc = ThisApplication.ActiveDocument
    ' Set a reference to the active sheet.
    Dim oActiveSheet As Sheet
    Set oActiveSheet = oDrawDoc.ActiveSheet
    ' Set a reference to the drawing curve segment.
    ' This assumes that a drwaing curve is selected.
    Dim oDrawingCurveSegment As DrawingCurveSegment
    Set oDrawingCurveSegment = oDrawDoc.SelectSet.Item(1)
    ' Set a reference to the drawing curve.
    Dim oDrawingCurve As DrawingCurve
    Set oDrawingCurve = oDrawingCurveSegment.Parent
    ' Get the mid point of the selected curve
    ' assuming that the selection curve is linear
    Dim oMidPoint As Point2d
    Set oMidPoint = oDrawingCurve.MidPoint
    ' Set a reference to the TransientGeometry object.
    Dim oTG As TransientGeometry
    Set oTG = ThisApplication.TransientGeometry
    Dim oLeaderPoints As ObjectCollection
    Set oLeaderPoints = ThisApplication.TransientObjects.CreateObjectCollection
    ' Create a couple of leader points.
    Call oLeaderPoints.Add(oTG.CreatePoint2d(oMidPoint.X + 10, oMidPoint.Y + 10))
    Call oLeaderPoints.Add(oTG.CreatePoint2d(oMidPoint.X + 10, oMidPoint.Y + 5))
    ' Add the GeometryIntent to the leader points collection.
    ' This is the geometry that the balloon will attach to.
    Dim oGeometryIntent As GeometryIntent
    Set oGeometryIntent = oActiveSheet.CreateGeometryIntent(oDrawingCurve)
    Call oLeaderPoints.Add(oGeometryIntent)
    ' Set a reference to the parent drawing view of the selected curve
    Dim oDrawingView As DrawingView
    Set oDrawingView = oDrawingCurve.Parent
    ' Set a reference to the referenced model document
    Dim oModelDoc As Document
    Set oModelDoc = oDrawingView.ReferencedDocumentDescriptor.ReferencedDocument
    ' Check if a partslist or a balloon has already been created for this model
    Dim IsDrawingBOMDefined As Boolean
    IsDrawingBOMDefined = oDrawDoc.DrawingBOMs.IsDrawingBOMDefined(oModelDoc.FullFileName)
    Dim oBalloon As Balloon
    If IsDrawingBOMDefined Then
        ' Just create the balloon with the leader points
        ' All other arguments can be ignored
        Set oBalloon = oDrawDoc.ActiveSheet.Balloons.Add(oLeaderPoints)
    Else
        ' First check if the 'structured' BOM view has been enabled in the model
        ' Set a reference to the model's BOM object
        Dim oBOM As BOM
        Set oBOM = oModelDoc.ComponentDefinition.BOM
        If oBOM.StructuredViewEnabled Then
            ' Level needs to be specified
            ' Numbering options have already been defined
            ' Get the Level ('All levels' or 'First level only')
            ' from the model BOM view - must use the same here
            Dim Level As PartsListLevelEnum
            If oBOM.StructuredViewFirstLevelOnly Then
                Level = kStructured
            Else
                Level = kStructuredAllLevels
            ' Create the balloon by specifying just the level
            Set oBalloon = oActiveSheet.Balloons.Add(oLeaderPoints, , Level)
        Else
            ' Level and numbering options must be specified
            ' The corresponding model BOM view will automatically be enabled
            Dim oNumberingScheme As NameValueMap
            Set oNumberingScheme = ThisApplication.TransientObjects.CreateNameValueMap
            ' Add the option for a comma delimiter
            oNumberingScheme.Add "Delimiter", ","
            ' Create the balloon by specifying the level and numbering scheme
            Set oBalloon = oActiveSheet.Balloons.Add(oLeaderPoints, , kStructuredAllLevels, oNumberingScheme)
End Sub
If my reply was helpful, please give a "Kudo" or click the "Accept as Solution" button below (or both).
Replies (0)
