Work Plane
Work Plane
It would be handy to allow a plane to be created based upon two coplanar axes.  Right now Inventor allows for a plane to be created based upon two coplanar edges; seems to me using axes would be the same result.
Right now I have a sketch with a line drawn at a specific angle from vertical and another sketch which is symmetric to it about the XY plane.  I need to create a plane through those two lines in two sketches.  This is a bit cumbersome because I have to create and dimension two sketches in order to create the plane.  Alternatively, I could create an axis through the first sketched line and mirror it over and use those two axes to create the plane...much quicker.
1 Comment
inv.ideareview
Status changed to: Archived
Thanks for sharing your Idea. We use this forum to guide product development and help users in the best way we can based on voting. We occasionally merge Ideas or archive old ones to keep the forum working properly- it ensures there is room for people to review new Ideas and that the most relevant and meaningful ones can gain votes.
We’re archiving this Idea because it's been on the board for well over a year and hasn't received many votes from the community. If you want to raise it again and try to gain more support, you're welcome to do so. We’ve found that pictures and mock-ups can help get concepts across and win more votes from other users. If you have questions or see a connection between this Idea and others, let us know.
- Inventor product team (Inv.idea review)
